911/912 front hubs and 1969 and later 911 108mm driveline parts
The 911 108mm (size of the CV joints) and all axel related parts can be used on 914s to do the proper 5 bolt conversion or if you have a 914/6 conversion with a high horsepower/torque engine these will handle the extra load. Much larger CVs and 10mm bolts instead of 8mm.
6- inner drive 108 flanges. Goes into transaxle. $160 each
7- elastic bolts for above flanges. $20 each
9- outer 108 drive flanges. $150 each
9- 5 bolt hubs. $150 each
10- 108mm CV joints. $80 each
30- 10mm CV bolts. $10 each
18- 10mm drive flange washers. (moon plates ( $15 each
?- Caps for CV joints. Yellow zinc plating that will need to be redone or buy new. $20each not shown
?- CV rubber boots. $15 each. Not shown
911/912 front hubs, 5 bolt.
2- 32mm front hubs. $170 each
2- 40mm front hubs. $160 each
8- 48mm front hubs. $150each
12- hubcaps for hubs. $20each
All parts have been bead blasted and painted or primer except CV joints which have been thouraly cleaned.
OR BEST REASONABLE OFFERS
