QUOTE(Tdskip @ Sep 12 2019, 10:15 AM)
Good morning / welcome / Congratulations on the car
As a new owner there are two really useful things you can do to help get your knowledge ramped up here. The first is to post lots of pictures of your car on any areas that you have questions about. The second is to make extensive use of the search capabilities because they will give you insight to prior conversations that often are helpful. Now with that said, by, and I’m sure others, would encourage you to simply ask as you’ve done because it helps keep the discussions here active.
There can be some debate about how thick the engine oil should be but the recommendations you were given are OK Assuming you meant 80/90 gear oil, but make sure the transmission oil is GL5.
A better way to search the site is to use Google and type:
site:914world.com subject
I seems to work better than the built in search function. Welcome as a new owner!
Ray
