QUOTE(80’s old school @ Sep 25 2019, 10:28 PM)
QUOTE(jb57tub @ Sep 25 2019, 05:49 AM)
Trying to determine if a T1 oil pump is replacement for the T4. I think they put out a little more volume. Other than the mounting stud lengths has anyone dealt with this? I also have a deep sump addition to add, along with a remote oil cooler and fan set up. Am I shooting myself in the foot, or on an ok track? Damn hot down here in South Texas. Rebuilding engine from 1.7 . Standard 66 crank, 96mm c/p, 1.7 heads with 42 and 36 valves, at this time Webers, but who knows. Any help is welcomed, Jon
Hope you go with an aftermarket cam.
I have a 1911. 66 crank and 96 c/p. Mine has a stock cam and I have 40mm Weber’s.
Great running engine, but runs out of grunt after 4800 RPM’s. Lots of midrange torque though.
Will be putting in new cam, will have to figure out which one. Using an old Supertrap exhaust, think I am probably going to with something like Fitech injection set up. Just thinking now but would like the tech help and simple system. Have Dell 44s but will most likely dump them. I have a big bore 2 ltr motor that came out of my car that was built back in the 90s in Cali, Big bore, (don't know the cyl bore yet) big stroke, heavy duty p/c, no bump rods, but just figuring out what I have. Just found a note to the builder, Bernie Bergman, Escandido, Ca. I have the engine torn down , but have not measured it yet.
