QUOTE (ArtechnikA @ Jun 30 2005, 12:37 PM) |
lots of cars use the boxer design, and have for about a hundred years. even some Ferraris called their flat engines boxers, although AFAIK, they weren't, they were actually 180-degree V engines... i don't think there is any direct connection between the Subaru engine and Porsche. OTOH - Porsche has licensed AWD technology from Subaru for the Carrera 4's front drive. we have an all-Boxer fleet: 1 Porsche 4, 3 Porsche 6's, 1 Subaru 4, 1 Subaru 6. _______________ technical footnote: a Boxer engine is a flat engine with pair of cylinders 180-degrees apart. in operation, they move toward another, then away. this does tend to compress the air in the crankcase when the pistons move toward one another at high speeds and there can be a fair amount of air moving around inside the engine in operation. but it makes for very smooth operation. in a V-engine, pairs of cylinders share a crankpin. in a flat V engine, such as Ferrari's 312, the cylinders move back and forth in pairs, always the same distance apart (since they are both on the same crankpin...) |
