QUOTE(Mikey914 @ Oct 19 2019, 10:14 AM)
Switch is on the column. So I'd start looking there as you were just there. Look for any indication that what was installed is wearing on something. check the switch visually. If not probably a wire. My money is problem is in the column from what you said. Usually if it happens after you have done something it's something you just did. Occasionally random things happen, but it's a start.
Try putting the old wheel back and see if it still occurs.
The same thing happens with mine. I have the OEM steering wheel. Turning can act the same as pulling on the headlight dimmer stalk. An old Pelican thread (2002) recommended checking the connection pins in the steering column. I'll start there.
