dcecc1968
Oct 24 2019, 01:01 PM
I'm getting ready to mount a passenger side mirror and I believe I remember a thread indicating that there are nuts welded in place in the passenger-side door already and all that is needed is to remove the door panel, find the nuts, mark the center with an awl and drill the hole from the outside of the door panel.
Am I missing any steps, or any helpful hints?
Oct 24 2019, 01:03 PM
You are correct.
dcecc1968
Oct 24 2019, 01:08 PM
Thanks Mark.
914Sixer
Oct 24 2019, 01:27 PM
Put tape around where you are drilling to keep the paint from pulling up or splitting.
Oct 24 2019, 01:37 PM
And the nuts are the in the same position on the door, left or right. So if you are brave, you can measure the drivers door and transfer the measurements to the passenger side without going inside the door.
914forme
Oct 24 2019, 02:15 PM
Pull the card and drill a pilot up through the center of the nut.
Easy way if you have a lathe you can make a guide via a proper bolt. If you have a steady hand you can drill the pilot out the center of the nuts. Process is not hard, but it was nerve racking for me the first time I did it.
I would also heat the area slightly to help the paint recover. Heat lamp works well or this. Tape is a great idea also as previously stated.
dcecc1968
Oct 24 2019, 02:50 PM
Thanks for the tips fellas. Thankfully (not sure that is right word) my paint was way bad when I bought it, which is why I'm drilling the holes now before I get it re-sprayed.
I'm sure it'll be nerve-racking for me too... no lathe unfortunately, just me and Mr. DeWalt.
- Don
Garland
Oct 24 2019, 04:27 PM
dcecc1968
Oct 25 2019, 06:21 AM
Garland,
Your search skills are far superior to mine. Thanks for the thread!
-Don
dcecc1968
Oct 25 2019, 06:43 AM
removed errant post
maf914
Oct 25 2019, 07:06 AM
QUOTE(914forme @ Oct 24 2019, 12:15 PM)
I did mine in a similar manner. First I taped a decent area around the holes in case of slips with the drill. I started from inside the door with a small bit to avoid cutting the threads in the existing welded nuts. I then used increasing diameter bits and a tapered rotary file bit to open the holes from the outside, taking care not to damage the threads.
After the holes were complete and cleaned up, I gave them a coat of primer and then touch up paint.
dcecc1968
Nov 2 2019, 12:27 PM
Thanks for the help fellas. Passenger mirror install complete!
After opening up the door panel and seeing how much stuff was the in the way, I decided to have a go at it from the outside....
Measured a few distances using my caliper on the driver's side... measure again... then blind measure two more times and transferred measurements to the passenger door. The first hole was off center a little, but was able to correct it as I increased bit sized. For the second hole, just used the rubber gasket as a template and hit it spot on.
Then used a bit of automotive paint along the drill marks and mounted the mirror. Now time for a ride.
