Hi Mark,
Thank you for the Information.
Maybe I should have been more specific:
So First of the car is getting the 911 parking brake. No discussion!
Second I understand the difference between struts 3" vs 3.5"
I also understand, that there are no S or Alfa Calipers for the rear. in my case in that combination I would use M Calipers in the rear. If I where to use Boxster Calipers front AND rear I would use Stomski adapters.
The point is more like, is it worth going the extra step from S-Caliper or Alfa Caliper in the front and a M-Caliper in the rear to Boxster Calpers ALL the way around.
What are the experiences, is there a noticeable difference, especially on track. Second are there (big) draw backs with the Boxster set up I should be aware of. AKA wondering why not more people use it!
Has anybody used the Boxster Calipers with 15" Cookie Cutters?
QUOTE(mepstein @ Oct 26 2019, 03:35 PM)
First, are you talking front or rear?
There are no Alfa or S calipers for the rear, only 914-6, M or Boxster calipers.
If you want it to look like a GT, use 914-6 or M calipers on the back.
The Boxster calipers are lighter than the steel calipers but the Carrera rotor might even things out. Only the 914-6 caliper has a parking brake unless you use 911 e-brakes.
Same on the front. M calipers were on the six, S calipers on the GT. Use the M or Alfa calipers if you are staying with 3” struts. S & Boxster calipers require 3.5” struts and Boxster calipers also need adaptors.
Eric Shea’s threads are still some of the best on the web.
http://www.914world.com/bbs2/index.php?showtopic=105728http://www.914world.com/bbs2/index.php?showtopic=91963http://www.914world.com/bbs2/index.php?showtopic=4909
