second wind
Oct 26 2019, 05:08 PM
Hello out there......took car out this morning, '73 2.0, drove fine, noticed I was having a few extra grinds when shifting. Later in day could not get over to fourth or fifth. Thought cone screws had loosened but they were tight. Any ideas??
Thank you,
gg
CMONNETT
Oct 26 2019, 06:20 PM
check all the shifter bushings.
second wind
Oct 26 2019, 08:24 PM
I did check them all.....the one that the "ball" pops into does seem loose. The one around the shift rod is fine. Up front the one around the shift rod seems fine. Could the one "somewhat" loose one really affect the shifting that much? I hope so. Thank you very much for your help.
gg
lierofox
Oct 26 2019, 08:26 PM
Since it's a '73 check under the shifter itself too to make sure the pinch bolt hasn't worked loose where the shifter attaches to the tunnel shifter rod. If that's worked loose and the shifter shaft has spun, that would muck with the alignment of ALL your shifts and make everything feel a bit out of place.
second wind
Oct 26 2019, 08:46 PM
QUOTE(lierofox @ Oct 26 2019, 07:26 PM)
I tested it for tightness and the bolt was tight. I think I would see evidence if the clamp slipped....like shiny grooves or something. Appreciate the help.
gg
Mikey914
Oct 26 2019, 10:47 PM
My money is the bushings at the knuckle split finally. Mine did this.
This one.
The reason I say it's this one is that it happened overnight like yours did. The others will wear. It also looked intact.
second wind
Oct 27 2019, 12:35 PM
QUOTE(Mikey914 @ Oct 26 2019, 09:47 PM)
This one.
Thank you Mikey....I just happen to have two of your bushings in hand from some event somewhere. Well, I guess it is time to learn some more about my car. Thank you very much and I will update. Any procedure to follow available so I can educate myself befor e I muscle F__k it? Thank you again.
gg
sixnotfour
Oct 27 2019, 01:33 PM
ball cup bushing also..on trans
ChrisFoley
Oct 28 2019, 08:13 AM
QUOTE(second wind @ Oct 26 2019, 09:24 PM)
gg
The ball cup bushings should never seem loose. They do split sometimes and no longer support the ball properly, which could cause your problem.
Mikey914
Oct 28 2019, 09:53 AM
QUOTE(second wind @ Oct 27 2019, 11:35 AM)
This one.
gg
I did a thread here somewhere I'll see if i can find it and post a link. I'm taking it was these? You will know when you push the rod out.
Mark
Mikey914
Oct 28 2019, 10:17 AM
Here's the link -
http://www.914world.com/bbs2/index.php?sho...hl=lost+4th+5thI'll also post up a GB for those suffering from the issues on the side shift trans a complete kit look for the GB
I'll post it up shortly.
Here's what started it for me
Also DickStienKamp did a good write up
http://www.914world.com/bbs2/index.php?showtopic=56765
dr914@autoatlanta.com
Oct 28 2019, 10:58 AM
either a broken missing bushing or the clutch tube broke loose in the tunnel
Mikey914
Oct 28 2019, 11:07 AM
If yours is the shift knuckle the hardest part can be removing the pin. Soak it in PB overnight.
second wind
Oct 28 2019, 07:40 PM
So I found my problem with regard to my shifting not going into 4th or 5th.....the knuckle bushings aren't worn out....they are missing altogether. Would that cause the problem? Heavy on the sarcasm but at least I know what happened and the cure is on the way. Whew!! So Mark you were 100% correct!! Fixing these and all the others should do the trick. Thank you all for your help. More questions will come up but for now I am relieved to have found the root problem. WoooHooo!!!
gg
anderssj
Oct 29 2019, 12:08 PM
QUOTE(second wind @ Oct 28 2019, 09:40 PM)
gg
When the front coupler bushings go bad, they can disintegrate and go away. Here's what the remains of mine looked like inside the cover/boot:
Click to view attachmentCheck the cup bushing at the rear too:
Click to view attachmentBe extra careful removing the cone screws; make sure the Allen wrench is fully seated in the recessed head. You don't want to deal with a stripped out screw....
second wind
Nov 3 2019, 09:15 PM
So my car is fixed!! Installed the 914 Rubber shift bushing kit and now have all five gears whenever I want them. Wasn't easy with a floor jack and the firewall bushing took some heat persuasion....but sure shifts nice now. Thank you Mark and Scott for all of your help and great parts. I highly recommend the shift kit to any 914 owner and I am going to buy a back-up kit just to make sure I can fix this issue again should I ever need a bushing or two. WoooHooo!!! Back on the road. Thank you again 914 Rubber.
gg
