LCOX
Oct 28 2019, 10:15 AM
Anyone using an aftermarket high torque starter and if so what brand and where did you get it. Are these starters dependable?
ClayPerrine
Oct 28 2019, 10:29 AM
QUOTE(LCOX @ Oct 28 2019, 11:15 AM)
I have run them for more than a decade on Frody and Igor. No issues with them at all, and they cured the hot start problems with Frody. With the Cayman trans in Igor, there is no room for a standard starter, so I will keep running the high torque unit. It turns the 4.0 high compression motor with ease.
The brand I use is from IMI, and I got them from Zims.
On Elwood, the original 914 starters have been superseded to a new, high speed starter. It works great too. I don't have a part number on it.
VaccaRabite
Oct 28 2019, 10:32 AM
Yes. I got mine from Ebay about a 12 years ago (or longer).
With all the problems I've had with my car, the starter has never been one of them.
Zach
02loftsmoor
Oct 28 2019, 10:49 AM
QUOTE(VaccaRabite @ Oct 28 2019, 11:32 AM)
Zach
any part numbers??
Oct 28 2019, 11:17 AM
I have a "Hi-Torque" starter that has been in my car for at least 15 years now.
Never had any issue with it and it has plenty of torque to turn over the 3.6L 10.5:1 engine.
Oct 28 2019, 11:23 AM
QUOTE(SirAndy @ Oct 28 2019, 10:17 AM)
looks like dis ...
raynekat
Oct 28 2019, 11:26 AM
i agree that high torque starters are great.
Have had one in a 911 for +20 years with zero problems and currently it's starting a high compression 3.6 engine.
Just put one in my 914 with a 2.7MFI engine as well.
So far just trouble free starting and it really spins the engine up quickly.
Don't know the brand name but I think you're OK with most of them.
You'll see some on Ebay and also places like Sierra Madre, etc in the $190-300 range.
brant
Oct 28 2019, 11:33 AM
The IMI starter is really the one to get
it costs about 2x what the ebay cheapies do
they work also
but not as well
I have both
the ebay starters are generic and don't have the right plunge depth on the housing. They require a proper shim to use
without the shim... many people have had damage to their flywheels
I replaced one for a friend on his 6
the ebay Bendix will push out through the starter ring on the flywheel, so the Bendix gear is only riding on half a tooth of the starter ring
eventually it shears teeth off of the starter ring and a new flywheel (dropping the transmission) is the repair.
I would recommend paying the 250 price for the right one instead of the 150 price of the ebay units.
or making sure you have the correct shim mounted under the cheap starter.
my ebay unit is now having a hot start problem on my street car
but the 15 year old IMI starter in the race car is not
brant
phillstek
Oct 28 2019, 04:42 PM
Put one in my car about a month ago after the original failed. Half the cost of the Bosch and turns over the 3.2 with 10.5s twice as fast. Made in Poland. Very pleased with it so far.
Was recommended by a local highly regarded parts importer/ Porsche repairer I’ve dealt with for 40 years. They installed it and offered all options including OEM Porsche at $2000 and the Bosch at $1200. I chose the hi torque at $600 after they told me they’d installed them without issue in hundreds of cars.
sportlicherFahrer
Oct 28 2019, 04:56 PM
I bought the IMI-101N in anticipation of a -6 that never happened. Turns my 4 over with no issues, and has for 5 years now. These folks were great to deal with, and I would buy from again. Lowest price I found, and still seems to be at least competitive without doing much digging.
Good Vibrations
Mark Henry
Oct 29 2019, 08:33 AM
I've also switched to an IMI Hi Torque.
My old bosch was very slow turnover using the small Odyssey 680 battery on my high CR twinplug /6, it wouldn't even turn over the engine when it was new. It was bad enough of an issue that I was parking on hills.
Now with the IMI starter it spins so fast I don't think it takes a full revolution to fire. It's nice knowing it will start, as it often takes 2-3 tries to start my Weber carbed /6 when it's cold.
I'm still using the Ford solenoid just because it was already on there. I don't think it's required with the Hi Torque, so next year I'll test to see if it's needed.
VaccaRabite
Oct 29 2019, 08:36 AM
I think that the Ford solenoid is still a good idea, as it takes the strain out of the wire harness and ignition switch. I'm running one on my car.
Zach
iankarr
Oct 29 2019, 08:45 AM
QUOTE(brant @ Oct 28 2019, 01:33 PM)
they work also
but not as well
I have both
brant
I've seen oddly worn flywheels on those hi torque starters. Need to shim the starter attachment bolts with washers to pull the bendix back and increase contact with the flywheel.
ClayPerrine
Oct 29 2019, 01:22 PM
QUOTE(SirAndy @ Oct 28 2019, 12:23 PM)
looks like dis ...
Click to view attachmentThat is the exact same one I use. Two thumbs up!
jfort
Oct 29 2019, 01:26 PM
QUOTE(brant @ Oct 28 2019, 09:33 AM)
they work also
but not as well
I have both
brant
agree about damage too flywheel. just replaced flywheel and installed rebuilt regular starter. damage to flywheel was apparent
PatrickB
Oct 29 2019, 05:05 PM
QUOTE(ClayPerrine @ Oct 29 2019, 03:22 PM)
looks like dis ...
Same one I'm using too. Turns over my worn diesel (400 lbs compression) okay unless the engine is really hot.I think the compression is better when the engine is hot, it becomes a slow turn and wonder if it will start. NOT the usual hot start issue, still turning over.
Root_Werks
May 19 2021, 11:31 AM
Older thread with good info. There's a number of HTQ starters to choose from.
Googled the part number and it kept coming up with VW T-1 units.
Anyone have a decent source for the starter (for example) Andy is using?
roblav1
May 19 2021, 03:54 PM
IMI 101N is the way to go. Works fantastic on my 6.
Justinp71
May 19 2021, 05:11 PM
QUOTE(VaccaRabite @ Oct 28 2019, 09:32 AM)
Zach
Same here
It was listed as fitting a porsche 914 when I got mine.
May 19 2021, 05:29 PM
QUOTE(Root_Werks @ May 19 2021, 10:31 AM)
https://www.google.com/search?q=Hi-Torque+s...DCA0&uact=5First two results are for Pelican Parts ...
Root_Werks
May 20 2021, 09:32 AM
QUOTE(SirAndy @ May 19 2021, 04:29 PM)
Thanks Andy, wasn't sure if PP units were the same or not. Engines out, easy to swap, gonna just do it!
SKL1
May 20 2021, 11:58 AM
I got one from AJR (Alan Johnson Racing) 30-40 years ago for my '71. Still going strong. Did add a relay to aid in hot weather starting.
Root_Werks
May 20 2021, 12:02 PM
Made a PP order, needed other stuff. Got the $269 starter on the way. Don't need one and my 914-6 has turned over pretty well. BUT, while the engine is out and everything is easy to get to, replacing a lot of stuff.
Really good to know so many like their TQ starters that have lasted many years!
jtf914
May 21 2021, 09:12 AM
brant
This happened to me, just finished putting it back together. Had my Bosch starter rebuilt and went that route this time...
