tailwind22
Nov 9 2019, 06:05 PM
Does anyone know if 930 turbo Fuchs, 7" and 9", will fit under "standard" GT flares?
Nov 9 2019, 06:32 PM
9’s may or may not fit. Tires will make a difference. You want to check fit before you do bodywork and paint. The flares can be “adjusted” to fit.
TravisNeff
Nov 9 2019, 06:40 PM
15x9 ET 3
16x9 ET 15 about .5 inch less outer lip from the 15x9
I hear the 15x9 will take some bodywork to make them fit, but they will. As for 16x9 I haven't heard one way or the other if it took extra work.
Gmanscott55
Nov 9 2019, 07:41 PM
I am running 7 X 17 front and 9 X 17 rear. Tight on rear, but no rubbing issues. Running a 5 MM spacer on rear and 35 MM on front.
See Mike's comment above ...
ConeDodger
Nov 9 2019, 07:44 PM
These are 16X7 and a custom built 16X8.5 (built from 4 16X6 Fuchs)
@Harvey Weidman
tailwind22
Nov 9 2019, 08:43 PM
QUOTE(ConeDodger @ Nov 9 2019, 05:44 PM)
@Harvey Weidman
Good input from everyone - helps a lot!
Steve
Nov 10 2019, 08:32 AM
I’m running 17x9 Fikse FM10 rims. 255 racing tires fit, but due to the curb rib on my pilot sports, I had to drop down to 245 so they wouldn’t rub.
They are 6mm offset. The flairs are AA
sixnotfour
Nov 10 2019, 12:23 PM
first 3 pics 225/50 on 15x9
second 2 are 245/50 on 15x9 flairs reworked with lip rolled up. and green paint
tailwind22
Nov 10 2019, 06:52 PM
QUOTE(sixnotfour @ Nov 10 2019, 10:23 AM)
Thanks Jeff
John
Nov 12 2019, 02:58 PM
What is a standard GT Flare?
Mine has original GT Flares (not reproduction) and it has used 9x16 ET15 wheels for the last 35 years or so.
ConeDodger
Nov 12 2019, 03:23 PM
QUOTE(John @ Nov 12 2019, 05:58 PM)
Click to view attachmentThe factory GT flare used a thinner gauge metal and the flange (down by the sidewall is not as much. Mine (Replica) had to be trimmed to fit those wheels.
John
Nov 12 2019, 03:42 PM
QUOTE(ConeDodger @ Nov 12 2019, 01:23 PM)
I run those with (3) 1/4" spacers in the rear. 930 Turbo front hubs with no spacers.
Click to view attachment Click to view attachment Are the new flares that much narrower than the originals?
sixnotfour
Nov 12 2019, 03:53 PM
yours are installed perfectly,,, and your 16s fit the way they do because the section width is about 9.5 inches..where as my old big ass 245/50s are 10+ in. all planets are in alignment...there can be alot of install variables,,yours are spot on...l
IronHillRestorations
Nov 12 2019, 06:15 PM
I did a conversion on a car that had 16x9's in the back, and the bodyman that put the flairs on did it with those wheels on, it required a little extra fitting
sixnotfour
Nov 12 2019, 06:20 PM
Well my statement rings true..the only other person I know is eric shea,,he can barely run a 15x8....so it all depends on the install,,,Erics where cut off a factory car..
here is the full chart..
tailwind22
Nov 13 2019, 08:22 AM
QUOTE(sixnotfour @ Nov 12 2019, 04:20 PM)
Saving that chart in my technical files. Thanks.
Garland
Nov 13 2019, 09:03 AM
245/50-16 , 9” wheels on all 4 corners. See my build page
Garland
Nov 13 2019, 09:10 AM
QUOTE(mepstein @ Nov 9 2019, 07:32 PM)
When I did mine, I did not have the wheels and tires till after I mounted the flares. Just made sure everything was fit equally, to maximum width.
sixnotfour
Nov 13 2019, 10:08 AM
QUOTE(Garland @ Nov 13 2019, 08:10 AM)
John
Nov 13 2019, 12:25 PM
QUOTE(Garland @ Nov 13 2019, 07:10 AM)
Me too! When my flares were done, all we had were 7 & 8 x 15 wheels, but later figured out that 9x16 fit all 4 corners so it made it so much more simple. No problems except trimming some of the sheet metal in the front fenders to clear when turning the wheels. Used to run (2) 1/4" spacers on all 4 corners until swapped in a 930 complete front end and found out the hubs spaced the wheels out. Then we moved to (3) 1/4" spacers in the rears with 9x16 and no spacers in front with 9x16. I don't even think the lips are rolled, but they might be.
ConeDodger
Nov 13 2019, 12:29 PM
Here are the pictures I was looking for. As I said, the factory flares were a lighter gauge metal with less width on the flange. Mark had to trim mine so the tire didn’t develop any razor burn. Mark had a factory flared 6-GT in the shop that he was restoring to compare them to.
Garland
Nov 13 2019, 01:17 PM
QUOTE(sixnotfour @ Nov 13 2019, 11:08 AM)
Yep, I had to trim all 4 once I had the wheels. But only the top inside edge. The rest with spacers worked out. Minimum clearance inside and out, front just clearing the shock, rear 1/4” off the body.
tailwind22
Nov 13 2019, 08:26 PM
QUOTE(ConeDodger @ Nov 13 2019, 10:29 AM)
Mark who?
sixnotfour
Nov 13 2019, 09:20 PM
plan ahead, or be ready to make em fit..
