QUOTE(ClayPerrine @ Nov 14 2019, 02:54 PM)
QUOTE(tygaboy @ Nov 14 2019, 09:13 AM)
I procured a complete 993 rear set up. It bolts in at 4 points, fits a Boxster trans with the 993 axles and lends itself to conversion to pushrod activated shocks. (At least, that's my plan...)
I'll be following your progress. Best of luck with your conversion.
I would have used a 996 suspension. Same setup,but it doesn't have that hoop over the top. With the 993 suspension, you will have to cut a hole in the rear trunk for it.
Clay
Sorry for the hijack. Tube frame planned so I'll lose the hoop. It's not part of the 4 chassis mounts and can be replaced with something else. It came as part of the package so I just mocked the Boxster trans in there to see if it'd fit. It'd be pretty straight forward to jig up the hoop, replicate the pick-up point locations and build a replacement.
Same deal with the Boxster stuff.
Now let's see some tube frame fabrication!
