QUOTE(GregAmy @ Mar 10 2020, 04:45 AM)
QUOTE(JamesM @ Mar 10 2020, 02:22 AM)
May be more bad news for d-jet
Well crap.
I have not had a chance to digest all this in detail, but your bottom line appears to meet my experience over the last few days: the OE fuel pressure regulator is becoming scarce. One of my core reasons for developing a Microsquirt for myself was as a low-cost alternative to declining D-Jet parts (and tunability for mods); one of my design parameters was to do that with as few parts as possible. I was working under the ASSumption that the FPR was readily available new; that appears to be flawed.
Aftermarket adjustable "return/bypass" FPRs are common, but they won't fit into the stock bracket. I may have to rethink this paradigm and come up with something around an aftermarket part.
Your goals are the same that I had when I did my first install, only back then it was only the start of OEM d-jet parts supply drying up. Fuel pressure regulators going NLA is a fairly recent development though, from what I can tell sometime in the last couple of years. Its a bit of a surprise.
Take a good look at that part from the dub shop, i really think that may be the best bet. Using that 6AN to 5/16 barb bulkhead fitting it looks like it would mount in exactly the same way as a stock regulator, and the actual pressure regulator component is replaceable with modern Bosch of any pressure rating (or fully adjustable)
I think i may order one today just to play around with it.
