QUOTE(Rob-O @ Mar 15 2020, 02:43 PM)
Back in the day there used to be small aluminum (stainless?) threshold covers, usually machine turned. Maybe a set of those if you can find them?
Is that the ‘domestic loop’ material? I’ve found that the German loop holds up better. But the aftermarket carpets don’t have the same backing that the factory had. The factory backing helped hold the carpet in the shape it needed to be in to fit the area it was designed for. It’s the white/clear plastic like material on the back of the factory carpet pieces. That material helped hold the shape of the carpet...and helped the loops to its backing without unraveling.
I can tell from the loop it is the domestic charcoal. Perhaps we just offer up an individual piece at $25 ?
The German wears MUCH better. However, the domestic black we have is at par with the German stuff.
Let me know, I'm thinking maybe we could make a clear protector? something that would be easily removable.
