mankowski
Apr 11 2020, 07:38 PM
My door pocket cover does not have the spring on it that I've read about -- does anyone have a description of how/where it attaches to the cover, and/or a photo of it? I'd like to add one to my car. Thanks!
Apr 11 2020, 07:40 PM
One end on the cover. The other end attaches to the metal through a hole in the door card.
mankowski
Apr 11 2020, 08:20 PM
Thanks, I'll need to remove the door card it sounds like.
I'll put a WTB ad and see if anyone might have a spare, or at least a photo of the correct length.
Apr 11 2020, 08:47 PM
You don't remove the door card but you do have to make sure you grab the metal behind the card and not just hook it into the vinyl and cardboard.
rgalla9146
Apr 12 2020, 05:59 AM
Mark is right, leave the door panel on.
It's not easy.
The long hook attaches to the lid. the short end to the hole in the panel.
Attach the front screw loosely, lower the rear to hook both ends of the spring, raise the rear(lid closed) and fasten loosely.
Use a cratch awl to find the three lower holes.
Tighten all.
drem914
Apr 12 2020, 09:13 AM
QUOTE(mankowski @ Apr 11 2020, 07:20 PM)
@mankowski when you put in your WTB let me know as I to have lost mine along the way and would like to get a replacement. TIA
mankowski
Apr 12 2020, 02:00 PM
QUOTE(drem914 @ Apr 12 2020, 08:13 AM)
WTB ad is up and already have a kind offer from KevinW to send me a spring and a plastic cover that apparently also goes along with it. Many thanks to all!
I’ll PM you if there are additional responses to the ad.
TypeJ
Aug 14 2020, 01:36 PM
Thanks everyone! You just saved me some heartache
914_7T3
Aug 14 2020, 01:49 PM
@drem914 PM me your address as I have an extra spring with plastic surround I can send you.
TypeJ
Aug 14 2020, 02:04 PM
Turns out there is actually a metal grommet in the door card that the spring anchors into. I had been poking around searching for a hole in the interior of the door before I took a peek and realized, nope. There is no hole there. The picture is bad because I just popped out the back of the door card to look, but you can see the grommet just inside of the plastic door card "pin"
porschetub
Aug 14 2020, 04:21 PM
The "bastard" spring !!!,Rory had the best solution,I found you can't really get the spring back on with just long nose pliers
drem914
Aug 14 2020, 10:56 PM
QUOTE(914_7T3 @ Aug 14 2020, 12:49 PM)
@914_7T3 Thanks I now have a spring. My problem is the two map pocket flaps I have both have the slot that the springs hooks into worn down over time and use. So, even if I get the spring in place on the door and on the flap, once it closes the spring lets go at the flap point of connection.
PanelBilly
Aug 15 2020, 05:46 AM
Leave it off. The cover stays down without it and then you can get your glasses out without having to hold it open.
