QUOTE(Superhawk996 @ Apr 21 2020, 03:02 PM)
QUOTE(mepstein @ Apr 21 2020, 03:36 PM)
They are pretty universal, i.e. a steel stud is a steel stud.
Pretty much true, but, the one consideration is what "grade" of hardware are they? All fastener hardware and/or studs are not created equal.
Common hardware store stuff and low end China is SAE grade 2. Low tensile stregth. Stay away from this stuff and I think that is what Jeffrey is trying to avoid.
What is needed is SAE grade 5 or equivalent Metric 8.8 These are medium tensile strength.
Critical fasteners for things like suspension will be SAE Grade 8 or equivalent metric 10.9 These are high tensile strength.
Very High tensile stregth CV joint fasteners and socket head cap screws are Grade 8 or better (like ARP fasteners) usually metric equivalent 12.9 and have some case hardening and/or more elaborate metalurgy and heat treat.
What he said
But seriously, appreciate the support.
What was learned today from talking to Phil among others is that these are unique to the 2.0 motors and VW type 4s. The 1.8 variant is also 56mm, but is an M9 that uses a step thread that are 8mm on one side and 9mm on the other. These are part# N0146841 and readily availble from vendors such as AASE sales.
I did indeed find the correct NLAs as the interweb is your friend if you know your part numbers.
