So I was able to drive around for an hour last night, constantly stopping to adjust the MPS which means there was a fair amount of idling mixed with short drives, engine always running. That equals a very warm engine and there was no stalling.
Just took it on the freeway for 20 minutes, AFR at a steady 13.5 while cruising and as soon as I get off the freeway it of course stalls again. I’m typing this in a parking lot 30 miles from home hoping the car will make the drive back.
I’m almost out of things to try. My car has become a paperweight just in time for summer again.
_____
**Update**
I let it sit for 15 minutes or so and it started right up and idled just fine. Made the trip home and it stayed running when I pulled into the driveway.
Back to basics: Air, fuel, spark, compression.
Under what conditions for any of the four categories above would allow the car to keep running fine with my foot on the gas with no <apparent> lack of power but stall when off the gas?
Air seems an easy one to take off of the list.
Fuel: Lines are new and good and new filter. Verified that the fuel pressure stays in spec even when the car wants to stall. Bosch fuel pump is mounted in the frunk and has less than 1000 miles on it. Injectors sent out for cleaning and are within spec. New injector seals.
Spark: New ignition harness. Tried both stock and electronic distributor. Tried both stock and new coil. NKG plugs and wires have less than 1000 miles.
Compression: Haven't checked, but car has good power and compression isn't an intermittent thing, right?
All vacuum lines replaced, new plenum hoses, intake gaskets, TB gasket, and NOS TB. Verified no vacuum leaks (including plenum). Tried 2 different MPS (both hold vacuum).
New CHTS, also tried swapping with old one.
Swapped relay boards (connections tested good on both of them).
ECU is next on the list to swap out. (I may have already tried this, but I can't remember).
So once at band camp..........
Electrical connector primary circuit somewhere....maybe even at the.fuel pump... loose or high resistance. When it gets hot....poof.
Could be the connector at the ecu is not seated completely.
