Full Version: Can you help make this easier
PanelBilly
What wire goes to what terminal?
PanelBilly
Never mind found another connector stuffed in the dash
ClayPerrine
The first one is the high beam relay. If you manage to hook the flasher relay to that circuit, your headlights are gonna go all Disco on you!
Just an FYI for everyone here. The flasher relay was never mounted on the fuse panel. There is a hole in the dash frame below the switches. That holds the headlight flasher. The factory flasher relays were too tall to put on the fuse panel mount plate.
76-914
QUOTE(ClayPerrine @ May 12 2020, 06:12 AM) *
Pics? how was it attached to dash frame? Clip? Rubber grommet? TIA beerchug.gif
