QUOTE(mepstein @ May 12 2020, 08:12 PM)
I know you said that before but every time I buy a car I can’t wait for the original tires to wear out so I can get a good set.
All depends on the defintion of a good tire.
In my case I'm talking about properties like balance, roundness, and radial harmonics that tend to exite other components, noises, or vibrations at particular speeds. Usually talking about ride quality of a particular tire.
There is always a compromise in tires. Ride vs. Steering Precision. Noise vs. Fuel Economy. Any of the above vs. cost. Wet traction vs. Dry traction. Wet vs. Snow.
Tires are a PITA.
So yes, it is entirely posible to switch from once tire to another that has a better attribute balance that suits your personal preferences. However, to gain what you like, you're likely giving up something else.
The other thing that clouds judgement is time. By the time you get rid of them you may not fully remember what you really started with and by then other aspects of your suspension have changed due to wear (bushings change, dampers loosen up, springs get a smidge of sag, etc.
Evaluation of tire A vs. tire B can be hard enough back to back with only the minutes required to do a tire change between evaluations. Doing that months or years apart and being able to do it in a repeatable blind evaluation is a marketable skill that few can do.
