Lg914
Jun 6 2020, 01:34 PM
If anyone is using the Patrick motorsports 6 tilting mount I need a bit of help. I need the measurement from the center pivot point to the bottom of the firewall.
Thanks for any and all help
Larmo63
Jun 6 2020, 02:54 PM
It kind of just goes in one place.....? Doesn't Patrick have any install instructions, or it didn't come with any? I seem to recall mine did.
sixnotfour
Jun 6 2020, 03:19 PM
the measurement to the pivot wont help ,, they are 2 different manufactures... you need the measurement from floor pinch weld to the lower mount holes....se your other post for the number...
Lg914
Jun 6 2020, 03:24 PM
QUOTE(sixnotfour @ Jun 6 2020, 04:19 PM)
Good to know.
Now I am looking for the measurement from the lower mounting hole to the the pinch weld.
Lg914
Jun 6 2020, 03:28 PM
QUOTE(Larmo63 @ Jun 6 2020, 03:54 PM)
Thanks for the help.
I have a naroescape Mount which puts the motor lower than the Patrick mount. I am trying to figure out how much lower. So I can decide how to proceed.
Jun 6 2020, 03:36 PM
QUOTE(Lg914 @ Jun 6 2020, 05:28 PM)
I like the Naro mount but it did give me some issues. I think it drops the engine too low and not only made the tin gap a bit but the engine sits lower and interfered with the shift rod. Ben had to rework his heat exchanger so I had clearance.
sixnotfour
Jun 6 2020, 03:40 PM
The real measuring point would be from the floor weld flange to the two bottom holes of the mount.. is 3 inches up from weld flange.
Larmo63
Jun 6 2020, 04:29 PM
My picture above is a 'before' dry mounted shot. Before we welded it, it got weld through primer, welded, and primed/painted.
Even though they are pricey, I like this mount.
Jetsetsurfshop
Jun 6 2020, 04:37 PM
QUOTE(mepstein @ Jun 6 2020, 01:36 PM)
Any pictures of a Naroscape Mount in a car? Would like to see the mods to that were needed. Shift linkage and what ever else needs to be altered.
I bought one off the classified's here. Hope it was a good idea.
Jun 6 2020, 05:00 PM
QUOTE(Jetsetsurfshop @ Jun 6 2020, 06:37 PM)
Directions are to mount it at the bottom of the bulkhead. I would just raise it up 1” or better yet, dry fit it like Mark suggested.
sixnotfour
Jun 6 2020, 05:45 PM
Narrow needs provide info....... Lots more want stock than racing.....
@naro914 Causing a lot of unnecessary tweeking, and problems
Patrick's instructions are downloadable..
any fire wall deviation will change installed height... But Narows is designed lower..
sixnotfour
naro mount..low boy
sixnotfour
Jun 6 2020, 06:39 PM
Patrick mount..install directions available to download PMS
