Is it a huge job to remove the driver's side pedal board so I can get to the master cylinder? Will a '73 have a reset button on the master cylinder? I bled and replaced fluid but that red light is still on.
One more question: Is it difficult to identify the idle screw on a 2.0? Remove the air cleaner? Idle is running around 1500. I think it should be more like 1,000rpm correct?
Thanks!
