QUOTE(Ampex351 @ Jun 17 2020, 04:49 PM)
OK....so I've checked the coil, good spark. Opened the fuel line while wife cranked the motor. No gas came out. Does that in itself tell me that the pump is dead?
You can hear the pump buzz just a little when you turn on the key but no gas out the fuel line to injector rails. Help!!
My coil worked great too when it worked. you need to drive it till it fails, then while it won't restart, then test the coil. Easy enough - grab a known good coil and the right wrench. Drive, when it dies, swap coils.
I agree Steve. A new coil is already on order.
