to assist.
a pic from when i was halfway through forming metal fuel lines on mine.
(you can see how far i am stretching my metal fuel lines across firewall in contrast to USA steel line set ups - but i have a rhd car with some different problems to negotiate).
you have to be careful looking at this pic because it is a rhd converted car,
ignore the handbrake cables you can see swooping out of firewall.
( i could not ignore them of course as i had to get around them).
lhd cars don't have that!!!
what you can see in this photo are the og plastic lines still clipped to rear firewall and heading right to where fuel pump is located (inclusive of the original clips that held the plastic lines to firewall.
this is a 74 car.
my car does not have the metal clip off firewall you have in your photos which i assume must be to mount a pre 72 fuel pump.
i have also posted pic from factory manual showing 72-74 fuel pump location. (you can see how hard it is to get a fuel line out the back of a two port fuel pump - the og pump was jammed right up in corner). the factory manual i have does not show the earlier fuel pump location. (other guys can correct me if i am wrong but i believe they did a recall on 914s and moved the fuel pump to the post 72 location - but probably left the original bracket there).
if what you have is a pre 72 with the pump bracket, (what i think i am seeing in your photo?) then the piping should be a breeze (maybe). its a straight shot.
you do a fuel filter at end of steel pipes and pre pump. its a low pressure filter.
BUT
(but i notice USA steel line kit isn't giving you a lot of room at end of steel tube pre mounting point for fuel pump if that bracket is the fuel pump mount).to consider - if you do the og pre 72 mount of fuel pump (if that is where it went), then you might get the original back in the day vaporization problems.
as suggested in previous thread.
you def. want a filter before the pump.
that is the original set up and it stops the crap that might come in from the tank. but if you want to be cautious, you can also have a high pressure filter after the pump to save your injectors (tending towards unobtainium) from the pump detonating its innards if it goes wrong, if you are retaining the injector set up.
i hope the factory manual photo makes sense of the tricky fit for the two port modern pump set up when you come to the 72-74 location.
the guys advocating a later 75-76 set up make a lot of sense.
its way less problematic given you cannot get the original pumps any more.
i contemplated it.
and almost did it.
and might yet, if the loop i had to make out of the back of the two port pump gives me problems in the summer.
i just tried to be as close to original as i could. not sure why now, given how much i had to change in the end.
i possibly could have done it differently by mounting my pre pump filter off the rear firewall before the pump and then shot the pressure feed out of the other end of pump.
but i committed to the pre pump filter in the og location for 72 -74. and i moved the FP slightly rearward of where it was jammed into corner of longitudinal and rear firewall - to get the line out of the back of the pump.
i did my post pump filter in the engine bay. there was no room left below.
Click to view attachment Click to view attachment
