I'm having issues with my 915 transmission and need to pull it from the car. While unhooking things under there I was surprised to find this sensor on the passenger side. My case is a 915/63 but I believe this is the speedo sensor from the last generation of the 915 (915/73). My speedometer has never been hooked up because I believed I needed to mill out a spot on the case due to the pinion gear being flipped for a 914. But the sensor for my case is different and would be on the drivers side. Does anyone know if the sensor that is there will work of i trace the wires and hook it up or does it need to be moved due to the flipped gear also?
P.S. Please excuse the grease and oil. I'm going to figure that out while under there too.Click to view attachment
