Well, it depends on which side of "original" you want to be on - more vivid yellow or less yellow than original. Yellow zinc is indeed available (it's basically white zinc with yellow dye added), but it's often a more intense yellow than the original CAD plated assembly (see bottom photo of assembly, with tag attached).
Also note that our bushing is the same material and color as original, and isn't bright white like some replacement bushings. Not that you'd want to replace only the bushing anyway - the locking pin usually wears out too, resulting in a "locked" lid that can be opened with a slight upward tug.
QUOTE(bbrock @ Jun 14 2019, 03:09 PM)
The guy who plated these parts is just fabulous
