Hi Rick. As I said in my post, I obtained the same test meter that PB Anders referred to. I have mine rebuilt now and bench adjusted. I got side tracked on my 914-6 conversion car and this car has been sitting. But it is installed. My goal is to get it started and then do some adjusting. I purchased an AFR meter that I can install, and I also have access to a CO meter for adjustment. I am learning it as well since there is nobody reliable around me that does it. I am happy to help you bench set yours up. If I am successful with the AFR install and tuning, Im happy to share the knowledge. It just may take a little time, I have to get the 6 on the road... hopefully in the next 2 weeks ( I have to travel for work next week).
We're not too far from each other so if you are totally stuck, hit me up. You have to be able to get to the adjustment screw which is that hardest part, removing that darn epoxy. You cant adjust without doing that.
I rebuilt mine, it holds vacuum, and all the electrics check out so far.
QUOTE(gonzo54 @ Dec 1 2022, 06:15 PM)
QUOTE(gonzo54 @ Dec 1 2022, 11:24 AM)
I'm not sure I understand half of the technical detail involed in MPS tuning and I don't have the equipment, so I'm looking for someone in the Southern California area that can provide this service. I know that I will have to add a Bung to my Bursch exhaust (cylinder #3?) Any advice or reource would be appreciated.
Thanks-Rick
Robert
@Robarabian do you have any MPS tuning contacts in So Cal?
Thanks-Rick
