What kind of a controller are you using to control the speed of the electric AC compressor?
The compressor has three rpm speeds one can select by connecting one of three wires (orange, green, and white, need to check colors:wacko:) to the evaporator signal wire. Or a three way switch is available to select speeds "on the run". I did not want one more controller, so tried the slowest wire connection and then settled on the second one after considering amp draw by the compressor and generation from the alternator. Not optimum or sophisticated but adequate for my purposes.
We used the 12v evaporator wire to power a relay that would connect the black wire to one of the colored wires on the compressor, to select the desired speed.
Otherwise, i plan on using a relay to power the compressor from the evaporator and using a SPDT toggle switch to manually select the Low and Medium speed from the cockpit.
See below screenshot of my notes
