Full Version: What Gives?
914World.com > The 914 Forums > Originality and History
Jim C
When I bought my 1976 914 the VIN sticker was gone. I calculated the build date as last week in November 1975. When I received my COA from Porsche it listed a build date of 12/75. Figured I made a mistake. Had a new VIN sticker made with 12/75 build date. Perusing the VINs on the site here today, I noticed there were many cars with later VINs that showed build dates of 11/75. Are the COA's not to be trusted? What's the explanation for the discrepancy?
davep
QUOTE(Jim C @ Sep 18 2020, 11:55 AM) *
What is your Karmann chassis # on the paint code plate?
This is the date that the body was completed. Then it could sit for a short while until final assembly. At that point it will get the Compliance decal with a build date. I find this date the best indication of final assembly completion. Usually, the date provided on a CoA is an invoice date or date of retail sale. Thus one can rarely use CoA or even Kardex dates as a completion date. The big issue here is there is a disconnect between manufacturing and sales departments. You want a manufacturing date, but you can only talk to the sales department, and they can only consult their records and not manufacturing records.
So, can you trust a PCNA CoA? The answer really is "sort of". Engine # & paint code will be correct. Interior? Well that depends on if they provide the code and a full description. The 1x codes are black leatherette, but 11 is black leatherette with basketweave seat inserts; so if it does not spell out the seat insert type, then the CoA is not accurate. Transmission? My data source says that no 914 had the transmission serial # recorded. Options? Again it would be best if the CoA had both code and a descent description. But dates, can only be used as a "no later than" date.
The pseudo-CoA Reports that I make up have as much detail as I can get, and some of that depends on the information that I can get from the owner.
Johny Blackstain
The build date for my LE is February 21st, 1974. The doorjamb sticker says February 74. My COA says March of 74 dry.gif
davep
Built and completed before the end of the month, and shipped out the next month.
A lot of CoA's show the completion date as the first of the month. The real case is that they were shipped out some time during that month.
