I am offering up my fresh run on test stand and test fired in my car only 2.4 S spec engine. Includes the following
2.2 S pistons thermally coated
2.4 cast iron cylinders nikisal plated(Supertec handled it)
Flow improved oil pump
Reconditioned rods with ARP bolts
Fresh ground crank .010 under
Case machined .010 under as well both by supertec
Heads were ported and polished by supertec
Carrera tensioners
Steel studs with case savers
123 dizzy
Every nut and bolt has been plated
Carbs are idts with correct venturies and jetting for the solex cams
New throttle linkage cross bar, air filter assemblies, rebuilt alternator,
Includes on engine oil filter which replaces oil cooler.
1.5-1.625 stepped headers
Cleaned and cerakoted side shift trans with throttle linkage conversion
914-6 engine sheet metal.
914-6 sport muffler
No engine mount or oil lines included as they will stay with my car.
$19,000 obo and will split trans and consider core engines as partial trades..
I am only selling out of necessity as I really don't want to be engineless but you know how it goes. You can come hear it run prior to removal. This will be an as is sale as I can't be responsible for someone installing incorrectly or changing timing or forgetting to add oil etc.. This is very nice engine and documentation exist on the build here on the forum.
I will post a picture of it on the stand. Please note the steel air filter is not included..
