Dave, good thing you caught it brefore it siezed up at 60 or 70.
What wheels do you run ? And or do you use spacers?
For anyone who uses off set wheels or spacers, on the 914 bearings, keep an eye on them, The large offset wheels and spacers, don't put an even load on the small 914 bearing, the 911 bearing's (and front end) are a much better choice for spacers and large wheel offsets, due to the larger spindel and larger bearings.
The best choice for wheels, is a wheel with an equal, inner and outer wheel width , or as close as possible, for example: 8" wide wheel optimum would be 4" inner spacing and the outer 4", that way the wheel is putting an equal load on the bearing. Unlike a 6" inner spacing with a 2" outer spacing, The 6 inches is putting twice the load on the bearing (extra 2" leverage) thats always pressing the bearing one way.
But, I know, can only use what you can afford, just keep a closer eye on the front end, if you do use other than optimum spacing.
