QUOTE(914sgofast2 @ Nov 7 2020, 05:32 PM)
I had a similar problem. Had to grind off some metal from the BMW calipers. However, on one side it was still slightly touching the wheel, so I eventually ended up using some thin 8MM wheel spacers and new longer wheel studs.
I am running a set of the old style Formula Vee aluminum wheels on my 1970 model year 914, so my fix would not be exactly the same as your issue. I also think there were two brands of 320i calipers. One is ATE and one is Girling, and each brand is slightly different in outer dimensions.
would you mind sending over a few pics of the wheels and how much of your brake caliper you grinded off?
