Jett
Nov 14 2020, 04:57 PM
Anyone have or know where to find the engine tin zap straps?
I had one that looked good but it was too brittle to use.
Thanks.
914Sixer
Nov 14 2020, 06:28 PM
May have to go deep, might have one. Check tomorrow.
Jett
Nov 14 2020, 07:41 PM
QUOTE(914Sixer @ Nov 14 2020, 04:28 PM)
Thanks, one step at a time
JeffBowlsby
Nov 15 2020, 06:03 AM
I recall that AA carries these.
rhodyguy
Nov 15 2020, 08:50 AM
There is a small pin sort of piece that pushes out of the center allowing for removal from the tin without cutting the 'loop' section.
Jett
Nov 15 2020, 10:21 AM
QUOTE(rhodyguy @ Nov 15 2020, 06:50 AM)
yes, I got one out but it crumbled in my hand.
914Sixer
Nov 15 2020, 10:41 AM
Mine were broken off,. not useable.
Jett
Nov 15 2020, 10:52 AM
QUOTE(JeffBowlsby @ Nov 15 2020, 04:03 AM)
Any pointers would help... tried looking at diagrams and search, but no luck.
Jett
Nov 15 2020, 11:08 AM
Found a couple of options from Amazon. Not stock but the look close.
rhodyguy
Nov 15 2020, 01:00 PM
As it's on the back of the tin and no one else will know, can you settle for less than OEM?
Jett
Nov 15 2020, 01:58 PM
QUOTE(rhodyguy @ Nov 15 2020, 11:00 AM)
You know me
. I’d love to find originals or have someone manufacture them.
rhodyguy
Nov 16 2020, 10:23 AM
As the sole reason for them is keeping the 'hot' starter wire off of the trans, source a couple of these until you find the correct ones.
JeffBowlsby
Nov 16 2020, 12:13 PM
Just search on the AA site. I found it easy using "cable tie":
Plastic Tie-wrap 914 Wiring Harness Starter Cable 99951300740
For the rear 914 harness where it is tied to the rear sheetmetal
http://www.autoatlanta.com/porsche-parts/h...n=99951300740#a
rhodyguy
Nov 16 2020, 12:17 PM
How much does AA get for them?
Jett
Nov 16 2020, 05:53 PM
QUOTE(JeffBowlsby @ Nov 16 2020, 10:13 AM)
http://www.autoatlanta.com/porsche-parts/h...n=99951300740#aThanks Jeff, I was searching for zap strap
$2.75 on AA and a bit less on Sunset with part number.
99951302340
