WTB Zap straps that connect to engine tin, Need three |
Jett |
Nov 14 2020, 04:57 PM
Senior Member Group: Members Posts: 1,637 Joined: 27-July 14 From: Seattle Member No.: 17,686 Region Association: Pacific Northwest |
Anyone have or know where to find the engine tin zap straps?
I had one that looked good but it was too brittle to use. Thanks. Attached image(s) |
914Sixer |
Nov 14 2020, 06:28 PM
914 Guru Group: Members Posts: 8,876 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
May have to go deep, might have one. Check tomorrow.
Jett |
Nov 14 2020, 07:41 PM
May have to go deep, might have one. Check tomorrow. Thanks, one step at a time (IMG:style_emoticons/default/smile.gif) |
JeffBowlsby |
Nov 15 2020, 06:03 AM
914 Wiring Harnesses Group: Members Posts: 8,490 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
I recall that AA carries these.
rhodyguy |
Nov 15 2020, 08:50 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,073 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
There is a small pin sort of piece that pushes out of the center allowing for removal from the tin without cutting the 'loop' section.
Jett |
Nov 15 2020, 10:21 AM
914Sixer |
Nov 15 2020, 10:41 AM
Mine were broken off,. not useable.
Jett |
Nov 15 2020, 10:52 AM
Jett |
Nov 15 2020, 11:08 AM
Found a couple of options from Amazon. Not stock but the look close.
rhodyguy |
Nov 15 2020, 01:00 PM
As it's on the back of the tin and no one else will know, can you settle for less than OEM?
Jett |
Nov 15 2020, 01:58 PM
As it's on the back of the tin and no one else will know, can you settle for less than OEM? You know me (IMG:style_emoticons/default/smile.gif). I’d love to find originals or have someone manufacture them. |
rhodyguy |
Nov 16 2020, 10:23 AM
As the sole reason for them is keeping the 'hot' starter wire off of the trans, source a couple of these until you find the correct ones.
Attached thumbnail(s) |
JeffBowlsby |
Nov 16 2020, 12:13 PM
Just search on the AA site. I found it easy using "cable tie":
Plastic Tie-wrap 914 Wiring Harness Starter Cable 99951300740 For the rear 914 harness where it is tied to the rear sheetmetal http://www.autoatlanta.com/porsche-parts/h...n=99951300740#a |
rhodyguy |
Nov 16 2020, 12:17 PM
How much does AA get for them?
Jett |
Nov 16 2020, 05:53 PM
Just search on the AA site. I found it easy using "cable tie": Plastic Tie-wrap 914 Wiring Harness Starter Cable 99951300740 For the rear 914 harness where it is tied to the rear sheetmetal http://www.autoatlanta.com/porsche-parts/h...n=99951300740#a Thanks Jeff, I was searching for zap strap (IMG:style_emoticons/default/sad.gif) $2.75 on AA and a bit less on Sunset with part number. 99951302340 |
Lo-Fi Version | Time is now: 7th May 2024 - 01:13 PM |
