Bleyseng
Jul 15 2005, 04:20 PM
Finally got a set of rear konis, #200lb springs, and the adjustable collars.
Brad you mentioned a basic measurement to set these up??
What the hell is it?
Thanks Jason for the parts.
DNHunt
Jul 15 2005, 04:56 PM
Damn my back hurts
Dave
rhodyguy
Jul 15 2005, 05:17 PM
i didn't get any fancy rubber snubbers when i bought mine!
wow!!!, and you complained non stop about how stiff your car rode and how it was unbearable for any distance. i'm sure it will be much more fun to drive thrugh fed way now
k
914werke
Jul 15 2005, 05:51 PM
I went 150lbs with mine
and that was the smallest available rate?
scottb
Jul 15 2005, 06:39 PM
rhodyguy
Jul 15 2005, 06:40 PM
i bought 100's when i got mine from hph.
k
Bleyseng
Jul 15 2005, 07:04 PM
Call Jason at Paragon Products as he is da man.
Kevin, I just asked Jason for new snubbers all around and they were cheap too. I was running #180 springs so #200 springs won't be much different just with the Koni's I will be able to adjust everything like I want.
Shoot, I will be driving the Axis Racing Soup Wagon support vehicle and I'll let Blair drive the car. Now I have a way to carry the tires and stay dry when I go to Bremerton! I can even keep the pop and beer cold.
TravisNeff
Jul 15 2005, 07:12 PM
You want to be about 40% lower than what the collar is for an initial setup.
Bleyseng
Jul 16 2005, 11:29 PM
Ok, but I was hoping for some sort of measurement as I do know how to use a tape.....
Jacques
Jul 17 2005, 12:15 AM
QUOTE (Bleyseng @ Jul 15 2005, 03:20 PM) |
Finally got a set of rear konis, #200lb springs, and the ... |
what company makes the 200#
http://www.paragon-products.com/category_s/198.htm
didn't see them here
nebreitling
Jul 17 2005, 12:03 PM
there's no basic setup ive heard of. plug 'em in -- then set the ride height where you want it, or go ahead and spring for a proper corner balance.
qa1142
Jul 17 2005, 12:07 PM
I went with #125's from Hyper-coil and pargon products. Back is fine
Brad Roberts
Jul 17 2005, 12:14 PM
I personally have found you dont need the snubbers in the rear. Front.. yes.. trimmed in half. The rear will never "see" them.
Geoff,
I start them 1 inch up from the bottom, when the threaded piece is flipped onto the shock at its lowest setting. It also depends on whether or not you have 8inch or 10 inch springs.
Nathan,
Most of the 4cyl cars end up very close when corner weighting them. The biggest difference will of course be the driver.
B
914werke
Jul 17 2005, 03:33 PM
is ther an advantage/disadvantage to 8 or 10" springs with a equivilent weight spring?
rhodyguy
Jul 17 2005, 05:06 PM
who are you going to have do the corner balance geoff? i should think a car with 200lb springs would ride taller than car with 100lb set on the same collar point.
k
TeamAxisRacing
Jul 18 2005, 11:43 AM
looks nice..
"I will be driving the Axis Racing Soup Wagon support vehicle and I'll let Blair drive the car. "
now thats the team attitude!
minor note i do believe this is my first post in about a year, bless the internet
