OK...so this weekend I was hoping to install my Sail Panel Kit. (I purchased this months ago from an un-named vendor.)
It seems to me that the material is a little sparse in terms of excess to trim.
In my opinion, the replacement side pieces barely overlap the edges. I realize the front and rear trim pieces will cover this, but, I expected to have enough material to cover at least to the lip (as per, I think it was Eric Shea's installation post several years ago - link attached).
http://www.914world.com/specs/sail_panel_install.php
The length of the top piece also is very tight...about 1/8 - 3/16" overlap to the sail panel piece on each end. (That's not over the end...it's just overlapping the weld seam by that amount.)
Does this look normal or should there have been a little more material for "forgiveness"?
