So what is the hot setup for "R" rated tires these days in the 205 size.
Kumho, Toyo, Yoko...?
what rims are you using them with.
Anyone using 5.5x15 steel wheels?
QUOTE (Dan (Almaden Valley) @ Jul 16 2005, 10:34 PM) |
So what is the hot setup for "R" rated tires these days in the 205 size. Kumho, Toyo, Yoko...? what rims are you using them with. Anyone using 5.5x15 steel wheels? |
QUOTE (Dan (Almaden Valley) @ Jul 17 2005, 12:42 PM) |
Thanks for the discussion. Since I plan on running either BI or BP, the widest wheel I can run under our current rules is a 6". If our region changes to the points based system then the sky is the limit depending on the points hit you want to take...I will probably wait until after the rules are addressed in Oct. and then decide on tire and wheel combination. If the rules change to points I may flair the fenders and use 8" fuchs with 245s all around. That is why I will wait for my paint and bodywork until after then. Yes, I consider myself more than a dabbler after 15 years of this stuff. The car will really be setup for Timetrials but the general setup should be fairly successful in Axs also. My last Bi car was able to usually run with the top 2 BP cars back in the mid 1990s when any of our AXs usually had 8-10 Bi and 8-10 BP cars at any given event. I usually try to guage my performance on the classes above me, not the ones I am running in, especially with AXing in a well set up 914. Nothing better than passing a 911 on the "big" track with a 4 cylincer 914! Back when Larry Sharp and I had 914s, at the time I had a 1.7L Ai car and ran headsup with the BP cars like his. Unfortunately I will have to learn to drive with less horsepower and no ABS all over again! |
QUOTE (Dan (Almaden Valley) @ Jul 17 2005, 01:11 PM) |
No, I did not get the yellow BP car I put the pics of up. I am getting a '74 virgin and and building it the way I want from the ground up. So I can do basically what I want. Just depends on where our rules go for next season. May cause quite a shake up. 4 banger 914s running against 996TTs in Timetrial...what are the adhoc comm. guys thinking about? Oh well, that is another discussion. Hope all of you GGR/Zone 7 AXers and TTers are looking over the points proposal. It will drastically change the face of competition in our zone. Make sure to be informed |
