Hi -
as a winter project I am cleaning up a relay board (removing all the old potting material, etc.) and doing a general clean up. I used the attached drawing from a fellow member (I would give credit but can't remember the thread I saved if from...) and everything seemed to check out minus a couple of findings...
For the fuse connections - drawing has F4 connected to C9 - ok, that checked out.
For the 12 pin connection it has C9 connected to F3 - but I don't have any continuity. Is that correct or is the schematic wrong?
Also for Relay R2 - hole E2 for the 4 pole ECU plug, I get not continuity from the R2 E2 hole to E2 spade connector, but I do get continuity from the E2 hole on the relay plug to the E3 spade on the 4 pole plug.
Any advice appreciated - of course the superbowl is on....
thanks,
RegClick to view attachment
