Mueller
Jul 21 2003, 03:16 PM
Are these specific to the year of the struts or a-arms??
I plan on going to HPH on Tuesday to purchase a bunch of stuff and I know that my struts are '74 /4 parts, but I have a few different -arms to pick from and do not know what years they are, or if it even matters
also....
I know some people have had problems with the rear wheel bearings as bought brand new, is there a specific brand to ask for or stay away from?
Brad Roberts
Jul 21 2003, 03:23 PM
The control arms are the same.. its the actual strut that dictates what ball joint you need. The early struts used a bolt thru the bottom of the strut to hold onto the ball joint.
The later struts use the "pinch" bolt style.
Those are the two "styles".. I have found a benefit to either one.
Rich will more than likely carry the "correct" wheel bearing that you need.
B
