Who has modified the new pads so the OE covers fit?
@bbrock describes what he did to make them fir on the first page of this thread. I was actually meaning to PM him the last day or so for more details as I want to get this done one way or another prior to the northeast gathering. Like the OP, I had put the rollbar pad on without the latch covers as a temporary solution, but now I need to get it resolved for real. I was waiting to see if the new latch covers were going to be available, but I just need to get it done at this point....
Hey Rob, Just a bit of an update. I carved out the openings on the roll pad with a dremel to allow the latch covers to drop into the openings correctly, but there was another issue when installing. Shrinkage of the pads caused the screw holes not to align will with the body so some prying and pulling was needed to screw the roll bar on. I started by screwing on one end at the corner and the using a stratchawl inserted through holes in the pad and rollbar to pry the pad so adjacent holes lined up enough to get a screw started. In some cases I had to use 1-1/2 inch screws to get them started at an angle, and then further pull the pad into place as they were tightened. Eventually the pad was pulled into place to fit nicely but there was enough twist that the latch covers lift slightly at the rear edges after all was installed. I need to see if additional grinding of the latch openings is needed for final adjustment.
My new pad looks much nicer than the cracked original but not quite concours due to these issues. Here's the final installed pic where you can see the slightly lifted latch covers.
The AA pads do look like they fit well but unfortunately, don't match OEM texture. Would be nice to marry the best qualities of each pad into one product.
