QUOTE(drem914 @ Apr 19 2021, 05:21 PM)
QUOTE(914Sixer @ Apr 18 2021, 09:47 AM)
Stock rear on ebay for $200. 914Werke has drop links. Rear clamps $22 a pair. Bushings available cheap. Shock bolts are about $100 each new.
@mepstein the bushings are cheap, but how do you separate the the ball ends of the sway bar and the shock bottom bolt from ther nylon bushings? Looking to remove and replace all the bushings when I do a little refinishing to clean up my 45 year old sway bar and links.
A torch makes short work of it if you are going to refinish, otherwise try a brass hammer or 2x4 piece of wood to pry it off, depending if it's still on the car or mounted in a vise.
