QUOTE(bdstone914 @ May 24 2021, 08:29 AM)
@dr914@autoatlanta.com The trans mount bolts are installed wrong. The head should be at the bottom. That allows them to be removed without removing the mount. Almost everyone gets this wrong.
diagram from the parts book is interesting.
opposite of factory workshop manual.
illustration photos in fwm show nuts on bottom and bolts captive.
fwm instructs
bolts on front mounts to be torqued and rear mount
nuts to be torqued. awkward to get a torgue wrench on a nut on top of the engine mount? you could get it on the bolt, but not the nut?
maybe it could be done ....?
fresh in my mind. we put new mounts in 18months ago.
pretty sure we pulled original trans mounts out. 99% sure.
evidence pointed to engine and trans never out of car.
can't speak for first 15 years and first owner.
i've never dropped it since 89 until 18 months ago.
had a paper factory build sticker still on gear box. sprayed undercoat intact in areas of mount etc.
found a photo before we started work, mounts visible in photos, nuts are down.
interesting parts diagram other way around.
Click to view attachment Click to view attachment Click to view attachment
