Hi all,
I still have an oil leak at the oil filler. (Tuna can). Oil rests on top of the lip at the mid point of the can.
I also have a rubber 19mm line rated at 350psi at the vacuum opening.
I did change the stock oil filler to a 1975 oil filler and air cleaner due to no venting on my new heads.
If I could get some insight regarding this I may be able solve this one.
Timing is set at 27btdc at 3500 rpm. Even when first starting car it only idles around 1200 and once warms the idle falls and does a low hunt and then dies.
It has the original CHT and it works (1973 2.0)
A couple pics to maybe add some perspective and insight.
Many thanks.
Click to view attachment Click to view attachment
