Rick B. and I were out driving our 2.0 914's today and comparing things. His is a '72, mine a '76.
I noticed at 2600 RPM I am indicating 52 mph, actual (GPS) of 51 mph.
Rick's 914 at 2600 RPM is indicating 60 mph......did not check actual with GPS yet.
Surprised at the difference.
I know the ratio between RPM and MPH will be wholly dependent on tire size.
His tires appear to be .6" less diameter (23.6" vs my 24.2") which would explain some but not all the difference. Yes - we need to check his speedo and see how accurate it is.
Someone have the actual gear ratios so I can calculate what actual RPM is for a rear tire that is 24.2" diameter/ 76" circumference? at 60mph?
TIA,
GN
