For trouble free 914 operation, check the following before going on a trip:
valve adjustment
tire pressure adjustment 26 F 29 rear
lubricate all suspension bushings
check front wheel bearing play
check rear brake pad venting clearance
check condition of brake fluid
check clutch adjustment
check dwell reading
check timing
check vacuum advance and retard, check centrifugal advance
change oil and clean strainer
change air filter
change fuel filter
check running fuel pressure (28 lbs)
check all lights for proper operation and aim front headlights
check and lubricate headlight mechanisms
check operation of shifter
check operation of accelerator cable and make sure it is very smooth
lubricate top seals with silicone grease
check condition of tires and riviera wheels for runout
check rear wheel bearing play
check tightness of rear swing arms
check charging system for a charge rate between 13.6 and 13.9
check condition and tightness of alternator belt
check cooling fan for debris
check for any oil leaks with engine running and hot
check for any exhaust leaks
check condition and tightness of transmission rear ground strap and battery ground strap
check tightness for the top of the engine block control unit white ground leads
check oil pressure switch for tightness and leaks
check operation of heater control flapper boxes and engine compartment blower motor
check instrument lights
check wiper motor and its speeds
check operation of turn signal switch for cancellation
check horn(s)
check steering column for tightness
check fit of windows
check locks for easy locking and unlocking
lubricate trunk hinge cups
lubricate all locks
check rear tail light housings for a good seal to the body
check trunk light for proper operation
check torque of wheel bolts to 90 ftlbs
check underbody for damage
check interior mirror for tightness of arm to base
check transmission and clutch for smooth operation
check fuel pump for excessive noise
check evaporative system for tightness including fuel filler neck seal
check fresh air fan for proper operation
check cigar lighter for proper operation
check instruments and odometer for proper operation
check high low beam relay for proper operation
check sequence of fuses and make sure that the fuse cover is installed
check emergency brake for proper operation
check interior light for proper operation and door switches
check seat sliders and lubricate as necessary
test drive and make any running notes
check battery condition and tray and stand for debris or corrosion and correct as necessary
check engine fuel hoses and under tank fuel hoses for condition and note and repair any leaks, make sure non intrusive hose clamps are installed
check condition of relay board and relays and make sure a good cover has been installed
check rear window and make sure it is tightly sealed
