Was doing a little rainy Sunday odds and ends work and had a couple of questions....
My seat belts are pretty lazy on the old 'retraction' front. I took the drivers side out and dug around in it. After rewinding the spring (that was fun), it retracts really nicely until I put it back in the car and it just cant seem to get past the bends and stuff the belt goes through to get to the bobbin. It works a little better now but still doesn't fully retract. Any secrets besides buying a new set?
Also, flashing brake light has been on so pulled the e brake switch out and hooked that back up (completely disconnected) so I know that wasn't causing it. I don't have the reset switch on the master cylinder. Brakes work fine but perhaps bleed them again? I had a shop flush and bleed them when I bought the car so I am sure they didn't do it right (order from furthest to closest etc). Could that be the culprit?
