QUOTE(Mikey914 @ Feb 9 2022, 12:34 PM)
Well the code really are out now.
Found that the thinner plastic wasn't readily available locally anymore. Had to source it and get it shipped in. It is in limited quantity right now.
So we will make the thinner ones as long as we can get the material, the cost is the same. We made the fist ones with the holes, so as noted in the PMs sent PLEASE use the message if you want without the hole for the overflow tube.
Thanks all for your patience.
Mark
Hi Mark, the 9am hose is not showing on your site. Thanks again!
