QUOTE(Montreal914 @ Nov 3 2021, 01:01 PM)
Issue is the fixed 2nd gear. You need a 904 shaft to adjust all gears.
Depends on what you're looking for, right? For example, if all you want to do is spread out 3-4-5 then it's not needed.
My 901 shaft was modified by a 914World guy so it can accept 901 gears (not mentioning the name in case he doesn't want to do another one). Basically, the gear was machined off and the splines cut in by hand. Works like the charm it is.
But yeah, a 904 shaft is the best ticket, if you can find one at any useful price. Last time I went looking they were ~$1500-2000 used.
