QUOTE(mmascari @ Dec 11 2021, 04:40 PM)
When I built my 914/6 conversion I installed a pierburg fuel pump. I connected the hot from fuse panel 8 to a switch, then to a 10amp fuse then to the fuel pump. I have been blowing the 10amp fuses for some reason not sure why. Do I need a fuse between the switch and the pump? If it is recommended then is 10amp the correct size? I am thinking about just removing the switch and the fuse entirely. How are others doing this?
When I wired my brothers 914-6 conversion this is what I did.
I used the original fuel pump wire to trigger a relay which then sent power to the fuel pump. The hot wire to the relay is fused. I moved everything to the front trunk. I believe I posted pics on his build thread. Was pretty easy to do.
