This is everything you need for plumbing for a 2.0 to 3.2 if not using any external oil cooler. It has the adapter fittings for the tanks and the engine case. I also can provide the 30mm to -12 adapter for the stock 914-6 oil cooler fitting.
Kits are 375 without the 30mm adapter and 425 with. This can be routed over the bell housing and no need for a hard-line so a huge savings that way plus does not interfere with the engine mount with this setup.Click to view attachment
