QUOTE(robkammer @ Mar 1 2022, 04:32 PM)
Hey Teeners, My fuel line project creep continues. My 74 had a washer pump mounted on the left side cowl support bar, on the bolt holding the wiper relay. I didn't like to look and tok it off and bought a new pump from AA that looks nicer. Two questions, where can I hide this, and am I correct to assume that the steering column wiper switch was upgraded at some point to send power to the pump?
I'm looking at the right side cowl post and thinking I can mount it to that, under the cowl out of the way and keep the hoses pretty hidden as well.
Thoughts? Photos would be great too.
And then, a really nice 76 went for strong money on BAT a couple of weeks ago and I spotted this photo. What would be attached to the pedal board? My 74 had the slots but nothing in the area that seems to have been mounted there.
Just wonderin.
Rob
Click to view attachment @robkammer i put my pump under the bottle. it should be in my thread, i took some pictures for the wiring and relay, because i got the Car Magic switch conversion to use the stock lever that when you pull , it triggers the switch and washer pumps. it eliminates the pressure feed from the spare and the corresponding washer lines, you route new lines from the pump directly to the spray nossles under the cowl, no more getting wet lap if a hose burst or comes apart.- I got my 914-6/911 pump from 914Sixer.
Phil
- and as others said, the slots are for the bolts that hold the metal bracket which holds the rubber clutch stopper and the picture shows the bracket but ismissing the rubber stopper. All suppliers can get you that bracket and / or stoppers.
http://www.914world.com/bbs2/index.php?sho...p;#entry2873724that link will have a few pictures of the pump , wiring, location etc. that i did
