QUOTE(Steve @ Mar 21 2022, 02:40 PM)
If you take the muffler bracket off of the trans does it lower it enough to stop the rubbing? If so elongate the holes on the muffler bracket to lower it.
QUOTE(ChrisFoley @ Mar 21 2022, 02:59 PM)
Show a picture of your trans mount assembly on the car.
IIRC, the stackup is different with them than with stock mounts.
It may be easiest/best to lower the trans by adding spacers on the big bolts between the trans and the mounts.
i will take a picture when i get home. I was thinking that too that a washer at the top of the transmission ear would lower it a tad, i may have to get longer bolts, there is only about a quarter inch sticking out the bottom .
on the issue of the bracket if you do that you are letting it sag a bit and then isnt that putting stress on the HE mount ears a bit?
Phil
